crazyjr
crazyjr's Avatar
01.29.2007, 09:08 PM
Originally Posted by neweuser
Many here have tested the MM using a ubec on 4-5s with success. As crazy said, he has a 4s 7xl/mm set up in his truck with no probs.
actually the current setup is for 5s, but not tested for heat
the 8000 4s packs will be great for you're setup with a 7XL. I'd go woth 4s over 3s as the power will be better. all you need to run this pack is a UBEC, because the internal BEC can't handle the extra voltage of the 4s pack
