Well, if you say it's ok, it must be since you're a mod. :)
OK, so, what motors do you want on there? I'll enter them, you just have to do the research. ;)
I'll need the following:
- Motor name/model
- kv
- max efficient rpm recommended by the manufacturer
- quality rating. This is a three point system; "good" (Feigao/Wanderer), "better" (Mamba motors, LMT Basic series, etc), "best" (LMT, Neu).
- The can size; 380, 540, etc
- motor length
- motor diameter
- weight
- flange diameter if any. (the raised area around the shaft)
- shaft length
- shaft diameter
The first 3 are mandatory and are needed for all motor calculator pages. The next 2 are for the motor selector page - if there are no values, that motor won't ever be offered as a choice. The last 6 are simply for informational purposes for the "Misc data" page.
