01.30.2007, 11:21 AM
Originally Posted by sleebus.jones
Do you have a part number handy? I was unable to find 'em, and my diff is bleeding silicone oil all over my chassis. That plastic ring is exactly what the diff needs. How did you go about making it?
I'm seriously considering a 777 diff, just for ease of maintenance.
Sleeb
I don't know the Ofna specific part number, but glassdoctor said these should work.
The plastic one I made was done simply by tracing out the size needed and using lexan scissors to cut the rough shape. Then, I used a dremel sanding wheel for the fine shaping. Note: Even though it hasn't leaked yet, I don't know if it will under actual use. To avoid the chance, I simply bought the real gaskets.
I thought about getting a 777 diff as well. Seems a lot less trouble overall.
