skellyo
skellyo's Avatar
01.30.2007, 02:26 PM
Originally Posted by dabid
I would triangulate the upper links some more so you don't have the axles wander, use a stock TLT link and make an alum. plate that goes where the stock servo mount is (make the new mount for the servo too), then bend up the back and install one of the stock single hole brackets as the upper link mount.
Might be just as easy to buy some from one of these sources:
http://www.montanascaledesigns.com/tlt_build_parts.htm
http://www.reignrc.com/accessories.html
http://www.bbyracing.com/rbxchassis.asp
http://bendercustoms.com/acc.htm
