06.19.2005, 04:20 AM
There probably is but i think to get the drive line level i would have to cut a channel for the spur. Also i was talking to jamie he said to get the right gear ratio on a diff with a bl motor you would need a rather large spur.
Also then there is the problem of mounting the motor, speedo. I just dont think it would look as clean as dafni's. But you never know.
