Bomb-Proof
02.01.2007, 11:32 AM
The constant voltage test can be calculated on paper, the only thing a dyno run would do is confirm the motor is in spec. On a true battery source, you would get useful info and real world #s. Batteries vary, but you need a random lipo pack to do the testing, and use same pack for every motor that uses that voltage range. Lipo packs are build to pretty strict specs and wont vary near as much as a Nicd or Nimh, so I dont ever expect to see a "matched" lipo pack for sale.
