Thread: Which Lehner
AAngel
02.01.2007, 02:07 PM
This is going into a Sportwerks Turmoil. I'm figuring that it's going to fall into the 8-9 lb category when all is said and done. I'm doing away with the mechanical brakes and am going with a single maxamps 4S2P 6Ah battery pack.
With the 4mm shaft diameter of the Lehners, I think that the Neu is a no brainer for me. Just about all of the helicopter sites sell module 1.0 5mm gears. And they can be had very cheaply. Heck, if a plain ole steel pinion lasts me a day of running, I'll be satisfied.
As for the spur, I did find a Kyosho gear that fits the screw pattern, but it doesn't match up in terms of everything else, like the accomodation for the bearings, etc. I'll have to keep looking or just go with another diff that is compatible with the Kyosho spur gears. Right now, I'm just anxious to get the whole thing up and running.
Since I've settled on the Neu motor, I suppose the final question is...1512 or 1515? The 1512 would have less torque, but that might not be a bad thing on a dirt track, as long as it still has sufficient torque to clear the triple that follows that particular turn. Quite frankly, I like the idea that the 1512 is around $40 less expensive than the 1515. This project is getting expensive. I just dropped $600 in batteries and that doesn't include the extra balancer and charger that I got so that I could have two charging at once. I don't like to wait. I haven't even gotten into what I've spent on 7075 stock to make sure that I'd have everything that I needed. If I didn't already have the MM controller, I wouldn't even be thinking about this motor.
On the other hand, at this point, $40 is just another drop in the bucket. :)
So...I'm hoping to be able to answer the $64,000 question. Is the 1515 overkill? Should I just go with the 1512? If I go with the 2000kv version, my max rpms will be under 30,000. Is that optimal for efficiency? Would going with the 1515 at 2200 rpm be better just for the sake of being in that rpm zone?
Geez, this just seems like a vicious circle.
