Originally Posted by Bomb-Proof
That was a Ue driveshaft.
So when you beef everything else up the breakage doesnt start over? But everything breaks as you say.....everything but UE??
This is how it goes..on an Emaxx
Driveshafts weak-upgrade to UE
Diffs weak- upgrade to 1/8scale
now idler gears are weak- upgrade to UE
1st-2nd gear,drive dog are weak- upgrade to ultrmaxxed
input shaft is weak-custom machine one w/stronger steel
wheel hex weak-upgrade to 23mm
Now....driveshafts break. It starts over.
I agree 100% everything breaks. If you can get something to absorb those stress spikes you can greatly reduce the amount of breakage. Steel doesnt give, it sheers.
I agree 100%, any vendor not just UE. People keep using UE as example, so I am also..I based my tests on UE. UE was the best example of a CVD at the time I was running the E-maxx, the "best you could get" Fill in the blank with any name brand you wish.
not exactly, true I dislike Robin, but has nothing to do with this. If it was RDlogics, I would say the benifit would be people who like RDlogics stuff would like the truck better.
Ok, upgrades are required for BL. Personal preference on what one wants to use.
