Nick
COOKIES!
Nick's Avatar
02.01.2007, 08:23 PM
I was thinking of trying renes trick. Put two spurs on with an extra long pinion
from mike. Have twice the gear mesh. That should hold. Just need to make
sure gearing is where I want it. I am thinking of going 10s lipo so lighter to.
Maybe a little less power but can't run wide open now.
I understand this now, that's a very cool trick. So basicly you are doubling the surface area for the pinion/spur.
EDIT: Just had another thought, what is dual spurs like with acceleration? If there is double the surface area, so double the rotational mass, would it effect it much (no doubt your setup wouldn't have a problem thoguh). I'm thinking of closing a door by pushing near the hinges here - if that makes sense. :)
~ Nick.
