Thread: slipperentials
neweuser
neweuser's Avatar
02.02.2007, 01:19 PM
Sounds like you want the strobe slipper set up. If you look for the sticky on that, you should be fine. You'll need the mod 1 pinion for your bl motor, then the mod 1 spur, both are sold here in the store. I'd give links to all the itmes, but at work so have not the time, sorry man, but go to the store anyway, there is much there that can be had for good prices, and Mike is the man that can get anything you need if you do not see it there!
