pinolelst
02.02.2007, 08:39 PM
Originally Posted by MetalMan
If you plan on running a TC4 at SoCal with a 5700 on 3s Lipo, all I can say is "good luck." Even the 5700 on 2s would be more than enough (just run your 8000mah packs one at a time). 3s Lipo would simply be too much for anything other than speed runs.
You might have heard me say this before, that the best way to find good gearing is to buy a pack of pinions and just see what gear causes it to run at the best temperature.
yep 2s is generally higher voltage than a 6 cell pack under load and much lighter....
pinolelst
