BP-Revo
BMW M Power!
BP-Revo's Avatar
02.03.2007, 01:59 AM
The Novak systems are not reverseable.
If you run the E-Maxx tranny facing in the "stock" direction with the shift linkage toward the front/spur gear toward the rear, then you must flip the Revo diffs over from standard Revo orientation (diffs have marking on them saying which side up - you should install with that side DOWN).
Or, if you are running a single speed (which I suspect you are) you can just rotate the tranny 180 degrees (what I have done). Both work well, and you can experiment with different setups which affect weight distribution.
Also, to let you know, with the HV ESC, you must either "rear mount" it - see my thread on it - just do a search for "Rear mounted ESC" or you must make some sort of spacer to move the ESC forward on the truck. The HV motor is too long and creates clearance issues.
