02.05.2007, 12:28 PM
Not sure if this has come up already, but a huge aspect of performance in brushless is the batteries.
Having dyno charts of all the different motors would be great. But there would need to be a lot of data to translate to predict actual performance. A motor would need to be tested under a wide range of voltages and loads.
Then a guy would need to know what his batteries can do... voltage drop under load... to match the right dyno chart.
But.... any dyno tests are welcomed if someone gets it done!!
