glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.06.2007, 01:56 PM
If you have access to an air compressor, one thing my buddies swear by is to use a light sprtiz of simple green... then blow it off... then a light spray of WD40...and blow it off.
This gets the it clean, protects from any corrosion, and makes it look like new.
This may not work for a neglectly filthy truck, but it works great if you do it regularly.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
