Neu 1512 pinion fitting issue
wallot
wallot's Avatar
Neu 1512 pinion fitting issue - 02.07.2007, 06:36 PM
the motor has so huge diameter that i am able to fit only 18T pinion
i need to use also 16T and 14T but cant position the motor as it already touches the transmition and cant move any further.
for 16T i need to move the pinion closer to the spur about 1mm and for 14T 2mm
any advice?
i am thinking of sanding the transmition case but dont think that I can take 2mm out of it
18T
14T
motor
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
