Re: Newbie Question
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
Re: Newbie Question - 01.31.2005, 08:05 PM
Originally posted by RacerXredraoB
Hello,
I currently have a Sportwerks Mayhem Pro 1/8 scale buggy and I am burned out on nitro racing. After reading some forums it looks like converting to a brushless setup is somewhat easy to do. My questions are:
Do you recommend the Feigao 9L or 10L?
Either will work well, depending on the gearing, and either will provide plenty of power.
Do you recommend the Warrior 9918?
The 9918 warrior will work fine in this application(as you can see!). The micro 18120 would be a better controller, as it has more adjustability and can handle hotter motors, but the 9918 warrior keeps the cost down.
The next event that I will attend for 1/8 racing will be the Dirt Nitro Challenge in CA.
Will this brushless combination with 12 GP3300 matched cells allow me and more importantly the buggy to keep up with the nitro counterpart?
Is there as much torque as a topend .21 and is the top speed similar to a topend .21 with a brushless system?
These converted buggies will run just as fast on the top end and have even more punch on the low end (will out accelerate the nitro buggies). I have beaten nitro buggies in drag races with my e-maxx!
What would the runtime be with this setup?
This I can't answer accurately - Hopefully studysession will check in and answer this based on his recent experiences. With gp3300 cells, you can definately finish a 5 minute heat, but a lot depends on the track, the gearing, etc.
Keith: a little help here?
Do you run the batteries in series or parallel?
Batteries are run in series, so 14.4 volts.
I read that using a 6v receiver pack will increase the steering servo performance, but add a little additional weight over using a UBEC. Is it recommended to use a receiver pack or UBEC in a 1/8 buggy for racing purposes?
I am pretty sure Keith (studysession) doesn't use either. The BEC in the controller puts out 5.5 volts, the ubec will put out a consistent 6 volts and the receiver pack will put out slightly more than 6 volts when it peaks, and the voltage will decline throughout the run.
Sorry for all of the questions, I just need to know if the performance of a brushless 1/8 buggy will be equal to a nitro 1/8 buggy before making the large investment.
Don't worry about all the questions. That is what these forums are for! Ask away.
Thanks,
Damron [/B][/QUOTE]
By the way, welcome to the site!
