Serum
Serum's Avatar
02.10.2007, 04:26 AM
Awesome conversion man!
Heading the right way for sure!! you could set for 4 shocks, saved some weight.
With the right batteries, that hvmaxx is a rocket. (if you manage to keep the truck light)
4S lipo would make it fast. the power from a brushless setup comes from the batteries, so if you use poor batteries, the speed will be poor. and the batteries you are using are most likely budget batteries. their internal resistance is high, meaning their voltage drops under the slightest loads.
What arms are you planning on using? aluminum or plastic?
Nice shell, looks very racy..
