02.11.2007, 12:11 PM
Originally Posted by Defcon
Bummer the Wanderer 9xl is out of stock would the 10xl be good or should I just go with the fiago 9xl?
Well, the 10xl will obviously be a little slower than the 9xl at the same voltage. If that's OK with you, or you can up the voltage a little to compensate, or don't mind gearing up a tad to compensate, then go with the 10xl.
