02.12.2007, 03:32 PM
Try turning the gears by hand- all 4 wheels should turn in the ame direction. If the front doesnt do much then the front diff may be stripped. Also try turning both the front wheels in the same direction and at the same time- the motors and rears should turn too. If not then the front is definately stripped/ on its way out.
