JakeE
02.14.2007, 08:23 AM
Originally Posted by glassdoctor
Yep... depending on gearing and traction, you can pull over 100amp spikes. My truggy with the 1515 hit over 120.
I think the highest I saw with the 1512/buggy was just under 120. But I don't use the eagle tree all the time.
But I have had runs in the street and lower traction tracks that showed peaks around 70-90amps.
At full speed the amps drop to around 30ish but every time you yank throttle and accelrate it will hit at least 50-60amps until the load drops (stops acclerating).
And average for the whole run is like @15amps.
Thanks for the info
