02.14.2007, 01:21 PM
josh -
not sure where you're at on your build, but if you're serious about the powerstrokes, don't get the RPM shock towers. because of their flexibility, the powerstrokes put unequal force on them causing them to flex away from center. (the bypass shocks don't put the same amount of pressure as the outside coil-overs). i now have to find different towers, and i'll prob. go with the FLM's.
just a heads-up.
