02.15.2007, 12:24 PM
I don't think it's the batteries... the MM has a hard time reading the backEMF or whatever it uses to "read" the motor and get it to fire. Basicly the MM expects to "see" teh same thing as with the CC motors, but the Neus are made different and confuse the poor little MM. :)
CC says it should only be a minor tweak to the software to make the MM compatible with them but you would think they could hurry up a little since it's so easy for them to fix. Or maybe it's not so easy after all?
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
