neweuser
neweuser's Avatar
02.15.2007, 12:57 PM
Originally Posted by BrianG
I assume you are using the RCM heatsink with it?
The bearings on my 10XL needed to be cleaned recently, but other than that, I've had no problems with mine either, and I use the RCM heatsink.
IMO, what makes the C motors more attractive to buy is the fact that the C motor is cheaper than the equivalent Wanderer once you add the RCM heatsink.
That is correct Brian. I use the RCM heatsink and the 10xl wanderer. I really like this motor too. It has been through a lot and is still like new. I only had to clean my bearings a few times, which is really easy to do. I also had a 9xl (wish I would have kept it) that ran really well. Same set up, RCM heatsink and all.
