jhautz
jhautz's Avatar
02.15.2007, 09:31 PM
Originally Posted by wallot
Is quark a 6S a123 cells capable?
I havent tried it but the A123 cells dont peak at as high of a voltage as lipo and my quark runs 6s fine after the voltage starts to come down a little. I would tink the 6s A123 would be just fine.
Originally Posted by cadima
Thanks for the input Brian. My plan was to mount the esc bottom side directly to my CRT chassis via CPU paste. Not sure if you've seen my CRT project thread but there's pics there showing the plan. I also don't want fans. Fans are band-aids. Use them only if you have a boo boo is my philosphy. But from reading above, it read like there was an issue with how the Quark conducted heat from the innards to it's own case. If this is the problem, my external chassis sink plan wouldn't have helped. I will be running a Neu 1515/2.5d on 5s. Think I am ok?
Your OK. That should work great.
to make it...
or break it...
Silent...But Deadly
