GriffinRU
02.16.2007, 11:20 AM
Temperature in C and related so far to copper losses only, later plan to add core losses but without proper info on core and windings would be difficult to do that.
Plan to add import and export feature for motor data as well as ability to create custom motor or edit existing. If ini file sound good for editing I will do that, but I was planning do that inside program. (smaller database)
I am working on adding nominal voltage calc for each motor turn and preset voltage automatically upon motor selection. Or voltage can be fixed (fixed battery type). By the way battery and ESC can be and should be covered as well. Right now total wires resistance to motor set at 0.025Ohm. Later I will add it as user selectable, based on FET's Rdon and Temp plus number of connections (deans, tamiya, anderson... soldered).
As for Alfa version it is possible to enter any voltage, double click on maximum value and replace it with new one.
Thank you all for feedback,
Artur
ID:	2425   Click image for larger version
