pinolelst
02.17.2007, 01:48 PM
Originally Posted by t-maxxracer32
well will that void the warrantee? i would have done it by now just dont wanna kill my warranty.
No it won't
just use a blade and sslice open the shrink tube on both connectors and peel it back for inspection. If there's a weak spot (and I bet money there is) just cut both connectors off and replace them with new ones.OIf it's obvious the wire is coming loose and that's the problem and not the connector itself you can clean them up and reuse them.
Make sure you re-cover the connectors with shrink tube.You could use tape but it gets messy after a while and can slide off
