wallot
wallot's Avatar
02.17.2007, 06:59 PM
thanks to much longer diff pinions I need also a new front dogbone as the MIP front pushes the drivecup/pinion too much back that it would strip the diff gears.
Let this be warning for FLM chassis with FLM hybrids users that 110mm rear and 70mm front dogbones are also needed because the 1/8 diff pinions are bit longer that the stockers.
Found a temporary solution ->raise the transmition about 6 mm up (cannot be more as the rear dogbone would touch the chassis thanks to increased angle) and it works nicely
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
