jhautz
jhautz's Avatar
02.19.2007, 11:33 PM
mike can make you an adapter so any 5mm pinion will fit the 4mm shaft. I have one he made. It works great. Used it to figure out the gearing I want with my 5mm pinions. Then ordered the correct 4mm pinion. But you could just use the adapter permanently if you wanted to.
to make it...
or break it...
Silent...But Deadly
