glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.20.2007, 12:43 PM
Originally Posted by t-maxxracer32
well i wouldnt mind buying a 7xl motor but wouldnt i have to use like 12 cells? or a 6s a123 cell setup? my mm esc wouldnt be able to handle that...
12 cells and 6s A123s is very different voltage...
Yes, the MM can handle 12 cells, but you should use a little bec regulator to keep it cooler.
7Xl and 12 cells would be a good setup...
Actually the CRT .5 is going to be a pretty badass little truck. It's just a little smaller than a 1/10 buggy... uses buggy tires. They are supposed to be out by the end of the month.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
