cadima
02.25.2007, 09:48 PM
Originally Posted by IBJAMMIN
Well I have finally got my CRT going and may have some advice for you.:032:
Pinions? I found the best deal on 5mm pinions at tower hobbies in the Heli parts section used on large scale electric choppers.
Mounting the motor is easy in the CRT I found a peice of 1/4" aluminum in the garage that worked great I drilled and sloted it for the motor and bolted it to the diff mounts in the brake pad holes and 4 bolts up from the bottom of the chassis. :027:
Jammin, can you provide a link to these pinions? I can't ever find em in my searches.....thx
