Thread: Emaxx questions
MetalMan
MetalMan's Avatar
02.25.2007, 10:20 PM
What you could do is get the Strobe slipper (much better than stock) with the Ofna 51t spur. Then, you could use the a pinion with the same number of teeth, but in mod1 (instead of 32p). It's a good way to lower the gear ratio and improve the slipper clutch at the same time.
