MetalMan
MetalMan's Avatar
02.28.2007, 11:02 PM
Brian, what thickness of aluminum are you using for your battery holders? I may try your technique with some 1/8" thick polycarbonate, and then use heat (torch) to soften the plastic enough to be able to bend the tabs.
