03.01.2007, 07:10 PM
I assume you were using the "motor selector"? If it came up with the overheating warning, your required RPM based on the values you entered must have been over 40,000. And the reason why it came up with no motors is because there were no matches (kv wise) based on the weight of the vehicle and the required kv to reach your desired speed.
What values were you entering? (Hint: use the "Export Values" button on the webpage, highlight the data, and paste it here in a post).
