03.01.2007, 11:13 PM
The number is the number of turns of wire in the motor. More turns means the motor spins less rpms per volt. Less turns means a faster motor. The XL part refers to the length of the motor. And you do want an XL for a larger truck like a Maxx. You pick the motor turns by the amount of battery voltage you plan to use while keeping the max total RPMs to about 35k.
