glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.05.2007, 07:09 PM
I think the MM has been great.
You can't separate gearing by itself... that depends on what the rest of the setup is... I can run a very tall gearing on my stuff because I have a lower kv motor, etc.
I see a slight gltich every once in a while but other than that I think the MM a great little controller... the software kicks butt... it's smooth... it's small.... it's cheap...
If it had a state of the art bec built in (and fix the neu issue) it would be perfect.
BTW, I believe the MMM will have a true swtiching bec so no more need for UBECs... can't wait for that bad boy...
The MM has run setups that thermal my ohter controllers... but to be fair, I never ran the others with a ubec... so maybe that was a big factor in them thermalling and smoking...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
