Serum
Serum's Avatar
03.06.2007, 05:19 AM
Welcome to the forum!
I am using the Integy housings. (the only integy part i have got to tell you the truth) Them, in combination with maximizer 7075 cups make a tough combination. Make sure to get some shimms to mesh them properly.
My personal experience is that nothing beat 7075 for diffcups. the 6061's are rather weak, and the pin will eat its way in the aluminum.
If you are planning on getting a very strong setup, i would advice you to use 1/8th diffs. (getting the FLM hybrids is a good option then) in this case it's more of a set and forget diff.
