jollyjumper
RC-Monster jumper
jollyjumper's Avatar
03.06.2007, 11:54 AM
if you only use a center torsen or lcd your truck will always power its rear wheels more then the front wheels.
it will therefore always break loose.
setup with torsen diffs are always either only the front,
or both front and center.
the bbf-models diff i made a tread about are used either:
front and center or,
front, center and rear.
but, you need different setup on the diff.
you need a looser rear diff, it needs to work more, if u understand what i mean.
hope this helps somewhat.
rene, you're funny
losi 8ight-t
xray xt8
