03.06.2007, 11:26 PM
Looks good!
From what I can tell, you're not using the disc brake? If not, you can remove all that stuff and save weight. Plus, it looks cleaner.
Have you run it yet? Because if you're using the stock tranny with no mods, and no mechanical brake, you won't be able to stop or go in reverse. There is a one-way-bearing in there...
