03.07.2007, 08:21 AM
hello,
i have tried to do what everyone has recommended with no results. my digital camera is down so i will describe my set-up.
- double battery positive wires soldered to a deans plug's positive
- double battery negative wires soldered to another deans plug's negative
- double wire bridge from the positive of one plug to the negative of the other
- all shrink wrapped
- using 2 x 7.4v 8000mah lipos
double motor wires:
- 5.5 plugs - one lead soldered into the plug
- second wire soldered to outside of the plug and shrink wrapped
- connected to motor
- UBEC positive soldered to positive lead and negative solderd to the negative lead
- both bridges removed
futaba 2pl radio with throttle channel reverse - i beleive the controller can't find neutral on the radio and cannot get it to recognize either the motor or radio. endpoints are at 100% and trim is at 0. tried an associated xp radio system with no results - will be trying a jr system tonight or tomorrow.
really confused - i everything seems to be solid and done correctly.
thank you for all the help
jim
let's build something sick!
