glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.07.2007, 11:05 PM
Originally Posted by VintageMA
I think you guys are missing something in your calculations of high voltage = less amps. If you take the same motor with the same KV rating, higher volts will = higher amps.
I know I'm not missing it... :010: ...to increase the voltage you must reduce the kv accordingly. I assumed that would be assumed. :030: hee hee
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
