glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.08.2007, 09:17 PM
What connectors are on the battery? You might try changing them/resoldering them and even shortening the wires while you are at it. Sure sounds like a bad connection/battery issue.
But it could be anything really.
You have a fat truck but still the MM should be ok... my CRT is almost 12lbs and I have never seen this.. and others have a similar setup to yours wihtout a problem.
Is it cold where you are? Is the battery at least at room temp?
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
