architorture
03.09.2007, 12:49 AM
Originally Posted by AAngel
I'm not running the wanderer, but am running the Feigao 7XL, which is essentially the same motor. I'm also using the MM controller with 4S lipo. I have had no issues with the setup and it is very smooth. I had, at one time in the no so distant past, wanted either a Lehner or Neu motor very badly. After actually done my conversion and using this MM/7XL setup, I've just stuck with it. It's hard to beat for around 200 bucks.
I'm running this in a buggy with 14/46 gearing. My 6Ah packs barely get warm and cogging, if any, is negligible.
What kind of runtimes and speeds are you getting with this setup? Do you have any idea how the 7XL compares to the 6XL?
