03.09.2007, 11:30 PM
One problem I see with teh boat/plane stuff is having the start-up be reliable. Historically they are 'finiky' and 'coggy' when used in cars...
The MGM I have has smooth start up.. no cogging. Maybe the HV MGMs would be a good choice.
I would look into the A123 cells for this also... if the will meet the weight goals you need. If you need really light setup you may have to go with a @ 2000mah lipo setup using good cells.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
