BP-Revo
BMW M Power!
BP-Revo's Avatar
03.10.2007, 02:26 AM
Personally, I would just get a proper Lehner motor with the Mamba Max ESC and run it on 4S in Delta configuration.
In the future, you can get the Monster Max and then re-wire the motor to wye configuration, which will reduce its KV by 1.73, allowing you to run the 6S no problem.
This will allow you to buy just one motor, saving you money. I know you seem set on using the Monster Max system as a whole when it comes out, but I can pretty much guarantee you that a Lehner motor will be better.
Also, its probably better to get two 2S2P packs and wire them in series rather than a 2 4S1P packs and wiring then in parallel.
