glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.10.2007, 02:05 PM
Nothing wrong with using the packs liek that. If you can get more use out of them with split packs go for it. I made up packs like that before (a pair of 2s packs) so I could run them in a 1/10 buggy at 2s or in my 1/8 at 4s.
The Feigaos are so cheap relative to the whole brushless project, I would not see the problem in planning to do two motors. Especially if a guy even thought for a second about getting a Lehner.... that $$ would buy like 4 XL motors...
If you want one motor... get 9XL. It's a good fit for your 50mph on 6s... and you can make do on 4s while waiting on the MMM. Gear it 18/46 and it will be very fast.
Seriously, I think you will find out that 50mph is overkill.. not that it's not cool... but low 40's is very fast and still jaw-dropping for most people.
Get some video if you have it running 50+..... I never gear mine that high so it would be neat to see it.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
