06.26.2005, 01:54 PM
Mike, your loosing it.. ;)
Give the guy a warm welcome..
Hi Felix! Welcome to this Forum!
Do you use the controllers BEC? what is your gearing end ratio? I guess the only gears that are on the car are ; pinion/spur and diffpinion/ringgear? and how much does your car weight? a good 8.5-9lbs?
I would use a motor in another kv range.
