A4DTM
03.11.2007, 06:28 PM
oh, also, the one pack was up to .104ah..
when i plugged it in this time, it started from .000 again.. will it figure out it already had some charge in it, as it goes along?
and, any idea what 5C2 means? i'm guessing 5 is for 5s, and C2 is..... ? - never mind, about that.. http://astroflight.com/store/pdffiles/109.pdf has the info
ok, one last question.. right now, the voltage goes from 21v to around 21.2v, in the 3rd stage of charging, which the manual says if normal.
the amps shows 0.00 and the mah is SLOWLY increasing.. like 1mah per 10 seconds.
i know it's almost completely charged, so i can take it off the charger...
now if I do the other pack, and take it off around the same time, the mah won't be the same as the first pack. i'm running these in parallel, so can I take one off with say 3950mah, and the other's at 4000mah, will they balance each other when running? i've also got 2 505guard balancers, that i'm doing to each pack after charging.. but i don't have a meter, to see how much they're different..
