skellyo
skellyo's Avatar
03.12.2007, 03:47 PM
Originally Posted by AAngel
I'd also consider running two of the trakpower packs in series, but I don't want to sacrifice the convenience of the charger/balancer interface that I have with the tp 1010C and balancer.
BTW, can two of the flightpower packs be charged in series? If so, is there a way to wire up the packs with a more conventional balancing tap so that I can use my tp balancer?
I would think it wouldn't be a problem to charge them in series if you can put together the proper balancing adapter. If you know what sequence the TP balancer wants on the cell taps on the connector, you should be able to make one up yourself. However, you'll still need the Trakpower harness adapter for balancing since the pack uses a plug versus having a connector hanging out.
