MetalMan
MetalMan's Avatar
03.13.2007, 10:54 PM
Originally Posted by BP-Revo
Took long enough :p
I'll have to come see it one of these days.
Also, it seemed like your post got kind of cut off.
Yes, you will, and no, it isn't. :)
EDIT:
It turns out the rear diff wasn't spinning smoothly because one of the bearings on the diff pinion gear is pretty much toast. One of the bearings on the center diff is also not smooth. Fortunately I had two good ones laying around, so those will be put to good use.
I'm now going to start designing the motor/center diff mount for this thing. If requested, I can post a pic of the 2-dimensional drawing that I will use as a template to cut this piece.
GD, are the Avid bearings ceramic?
