03.13.2007, 11:30 PM
Performance depends greatly on temperature. Those initial dips occur because the cell isn't warm enough (the IR increases as temp. decreases), and so once the cells warm up (IR decreases), then the voltage increases. If a cell is started at a higher temp. like 90 deg., it will perform much better, but might end up getting too hot at the end of a discharge, depending on usage.
